View Full Version : Jamming C8000
Saghir377
02-23-2013, 08:35 AM
Hello dears. I m very thankful to all of you this is really very good experience to come here and discus about problems.
I have one C8000 in duplex jamming only in 90gsm art mat paper. One side printed very well but in 2nd side paper jam in fusing.
Thanks for cooperation.
Mick01
02-24-2013, 10:39 PM
Hi,
Light coated stock (especially doublesiding) is difficult for any digital machine to cope with.
I have some suggestions that may help
Check the grain direction of the stock, light stock should be long grain. Short grain will want to wrap around the upper fusing roller.
Adjust the fusing temperature down, this may help to reduce the stock sticking to the upper fusing roller.
If doublesiding ensure the side with the least amount of coverage is printed last, this also may help with the stock sticking to the roller.
Make sure the fusing exit rollers (ceramic rollers) have the correct tension setting.
Replace the upper and lower fusing exit guides.
Hope this helps and good luck
