Gort
02-28-2013, 03:21 AM
I have a bizhub 601/DF-614 that is having problems with Mixed Original Mode only.
When I scan, fax, or copy from the DF using Mixed Original Mode the image is shifted left (to the front of the machine) in the main scan direction about 1/4 inch, then the shifted image is "pasted" on the right side of the image.
It does not do this when scanning off the glass, or in Long Original or Z-Fold mode or in normal scan mode.
I have reloaded the system code completely, reset the ADF adjustments, replaced the memory DIMMs, replaced all of the sensors in the DF and VR for the tray width adjustments. Short of throwing boards at it, it seems too strange to be a Image Processing or MFP board as it only happens from the DF.
The attached sample is rotated 90° CCW
Attached sample: 19687
