View Full Version : KM C6500 keep show C-2454
printduthu
03-15-2013, 05:13 PM
Hi,
I have just changed brand new Developer unit (a set/4 colors) for my KM 6500, I run " Service -> 02. Process Adjustment-> 02.Drum Peculiarity Adj-> 06.Toner Destiny Sensor Init with ALL " but the machine show C-2454 . I checked in I/O Checked Mode <54-09> IN : 226 (undertoned).
http://nv5.upanh.com/b1.s34.d2/0439f024a41ef33a519f48df7f734167_54024655.img0099a .jpg (http://upanh.com/view/?id=6vs99sew1zh)
Any ideas for me to fix this issue ? Thank you.
JustManuals
03-15-2013, 07:22 PM
Paul@justmanuals.com
copymech
03-15-2013, 08:21 PM
A common error when replacing the developer on these models is leaving the dev roller packing on. It is a rubber strip that looks like it belongs on the dev. It will cause all kinds of problems. Like blank, light, uneven etc. I even had one travel thru the copier and cause the finisher to jam. Hope this helps.
Texers
03-15-2013, 09:50 PM
Take dev unit out, take TCR off, clean it, clean that bit of sponge around the TCR, put it back, close m/c, start m/c in service mode, process adj, toner density initialisation. if it works, continue with m/c setup. if not, power off m/c, start again in service mode, go process adj, sensor output, toner density sensor output and run the routine. After a while it will go under 220. Do the rest of the adjustments.
hope this helps
printduthu
03-16-2013, 12:06 AM
Thanks for all !
