blazebusiness
03-20-2013, 06:06 PM
Strange problem with transfer belt assy. Replaced belt and entire cleaning unit 3 months ago after discovering that toner had turned to pebble like rocks inside old cleaning unit causing wear on the belt. Waste toner pipe was not clogged and nothing was interfering with the flow of waste toner out of the cleaning unit. Customer called back today with sc45-20 code and upon removing the Xfer belt assy the belt had toner build up on surface causing the code. Removed the new cleaning unit and again....waste toner turning to rocky pebbles inside unit. Fuser temp is ok and cannot figure out what would cause this as there was no obstruction to let waste toner build up in the new cleaning unit. Been working on the c500 series for quite a while and thought i had seen it all. Any ideas?
