View Full Version : Jamming Dialta Di200f scanner bed shakes and will not scan for copies.
motherslawn
03-22-2013, 03:42 PM
I have a Minolta Dialta Di200f. The scanner arm will not move and shakes rather violently. The machine will give a fatel arror and reset. Is this a easy fix? It is a old copier and I want to fix it myself or send it to the bone yard.
David
darry1322
03-22-2013, 09:31 PM
Check the foil coating on the back of the exposure lamp. If it has a cut spot you need a new lamp.
fixthecopier
03-22-2013, 10:50 PM
That spot may resemble a bubble in the foil.
motherslawn
03-23-2013, 04:58 PM
Will that cause the scanner arm to shake and not move?
Hansoon
03-23-2013, 05:41 PM
Yes, cracks or bubbles in the foil will cause arcing. Logic circuitry doesn't like that.
Sometimes you can put a dab of solder over the crack(s) to ensure conductivity over the whole length of the foil.
Hans
