BH 600 web issue
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    BH 600 web issue
    I am having problems with a couple of my most used machines, where I have changed the web assemblies. On two of the machines I have changed the actuator solenoid and on both of those machines the web quits moving, destroying the ufr. I can manually move the units and can see the actuator moving with the door pried open. I change the assembly, not just the refill, but they are not OEM. Have any of you had similar web issues?
  • Flash
    • 378
    Re: BH 600 web issue
    Reset the web counter at 250K. For some reason we have found that the web stops advancing when the web count goes past 300K. I know it will go 500K but the replacement interval is actually 250K.
    • Darren King
      copiertech
      • 652
      I have had the web drive gears become brittle and break.
      • fixthecopier
        ALIEN OVERLORD
        • 4714
        These are failing as new installs. I reset the counters when they are put in. I am starting to suspect the aftermarket webs. They seem to bind when manually checking them.
