View Full Version : MyQ monitoring software
Arc Angel
04-05-2013, 02:34 AM
Hello Techs,
I just needed to ask if anyone has ever worked with the MyQ monitoring software for printers and multifunctionals on a network. I found it while researching for a monitoring software, and I need a feed back on whether this software is legitimate and if any of you techs recommends this product.
Thanks.
Arc Angel
04-07-2013, 09:54 PM
Okay seriously no one has heard of this software?. Common someone must have used this product in the past. Anybody?..
blackandwhite
04-13-2013, 05:02 PM
myQ is working good on Kyocera models....the latest machine are comes with inbuild myQ platform....but for other make ...its working ok....the negative point is machine will be work on PCL mode.... check with cardadis...may be it will cheaper then MyQ.....
a advise....if u have more CMA copy contract customres....dont suggest MyQ...u will loss ur business..... sales guys never think about long time revenue.... please mind it.....
good luck.....
Arc Angel
04-14-2013, 09:08 PM
Hey "blackandwhite", so you are not recommending this software for monitoring?..And I am not sure what you meant by "check with Cardarsis"......
Thanks for the feedback.
blackandwhite
04-15-2013, 04:06 PM
sorry...its not cardarsis.... cartadis...its like myq....
may be it will cost u less.....myQ is ok with kyocera products....but for other brands u have to think about it.......good luck.....
Arc Angel
04-18-2013, 05:08 AM
Okay thanks for the feed back, but we are a Kyocera distributor, and we do not sell any other brand, so we want to have a monitoring software, for our machines, so that we can introduce it as a package deal to our customers. What do you think.
CARTADIS
05-21-2013, 01:22 PM
Hye,
As "Blackandwhite" said, you can look at our solution GESPAGE (Gespage - Gestion d'impression - Print, Copy, Manage (http://www.gespage.com)) by Cartadis. It's working with Kyocera and all the others brands.
Sincerly,
brunot
12-21-2018, 01:07 PM
Hello everyone,
Normally when a user print outside Myq queue, myQ report shows unknown. So How to prevent users from printing outside queues.
Thanks.
Hye,
Sincerly,
Kyo fan
12-24-2018, 12:13 PM
For that you need to check "Set up IP filters" when installing embedded terminals with remote setup, and that saves a lot of time.
The other way is to manually set IP filters thru Command Center for every device:
41330
In the IP Address(IPV4) field you will enter the IP address of MyQ server. Under Subnet mask field, you will enter 255.255.255.255 (in networking, this means: any network, any host).
For the protocols, check those as marked on the picture and restart devices after submitting.
spandx17
01-02-2019, 06:33 PM
MyQ is great software. Kyocera's KMnet Manager is actually MyQ, but with out other vendor support as well.
