Hacky
04-08-2013, 09:38 AM
Hi all,
Seem to be having a problem establishing which driver will allow a client to continue use of their C250 via their new Windows 8 computer.
I recently visited this client and installed the latest PCL driver I could find for the C250, this worked completely fine and while I was with the client, they were able to do everything as required.
Since then I have been called back to them as all of a sudden they are unable to print. So I went back, removed the PCL driver and tried re installing it, yet again it worked successfully and they continued using it. But now over the weekend I have been contacted by them once more with the same exact issue.
It seems like the computer is just dropping the driver and denying all knowledge of its existence. Obviously this is an older model, and there is no news on an actual Windows 8 driver for it, but the client does not sympathize with this and sees no reason why it should not work..
Any suggestions? Why does it keep doing this? Is there different driver I should use perhaps?
Thanks in advance!
Thanks in advance!
