error code C-3451 HELP!!
C450 copier
phamilton
Its a low heat code IE: the machine didn't make it to 100 degrees with in 50 seconds of the lamp turning on. If your not a tech call your local servicing entity and they will probably come and install a shiny new fuser unit for you............... For about $600.00 ............. If you are a tech do a trouble reset and see what happens, might want to have a gander at the thermistor for toner build up and clean as necessary. Could also be the lamp so do a continuity check on it and replace as needed or just replace the damn fuser and be done with it!I keep most working fusers that we replace in the field just for times like this so you have the unavailable part for the over priced, poorly manufactured, chinese, throw away POS fuser!
