View Full Version : 6000L error code
JSC
04-08-2013, 05:13 PM
Im off to a 6000L tomorrow with a C3102 error code. I only have the one out and from memory I think its to do with a one way bearing in the fsr, but seeing as Infohub is all f****d up im losing the will to live trying to find info on it.
Can anyone remember which gear/one way bearing caused this error or am I on the wrong path.
Cheers
tech51
04-08-2013, 08:07 PM
If I remember rightly it can be the three one way gears in the drive unit or the torque limiter that sits under the lower roller.
JustManuals
04-08-2013, 08:13 PM
Paul@justmanuals.com
tech51
04-08-2013, 08:39 PM
20268
Cheers
Battled the infohub and found this!!!!!
humpty dumpty
04-08-2013, 08:54 PM
C-3102 error code.
Solution
CAUSE: The Fusing drive gear /M (22T) uses a one-way clutch. After a period of time, this one-way clutch may slip and is unable to drive the gear.
SOLUTION: Replace the gear (p/n A03U 8093 11).
hope this helps
matt
JSC
04-08-2013, 09:48 PM
C-3102 error code.
Solution
hope this helps
matt
I think thats the baby. Cheers
20268
Thanks. Can't even get on to Infohub now. Just getting the spinning wheel of death...
Thanks already got it Paul.
Yes thats what Im thinking . Thanks
JSC
04-19-2013, 07:43 PM
* UPDATE *
Man it pisses me off when people don't update thier posts with the fix, and then i go and do it :p
In the end it turned out to be the Conveyance board or thr ADU board as it used to be called.
Thanks to everyone that posted ideas.
