View Full Version : Miscellaneous bizhub c364 yellow pain
drimouxlas
04-12-2013, 05:23 PM
Good day everyone, i got this white marks on a c364 already changed dev unit y, drum y and high voltage board, performed a printhead skew reset and initialization still the same thing.. i'm starting to think that might be something wrong with the transfer belt... any help would be really appreciated.
DigiMan
04-12-2013, 05:50 PM
Does this happen in 1st transfer or 2nd?Have you stopped the machine while printing to check this?
drimouxlas
04-12-2013, 06:01 PM
No i haven't but since we changed dev unit and hv i guess there should be something wrong on the second. Im thinking of the belt roller over yellow i've cleaned the connectors. i'll stop it on monday to check when it starts thanks
DigiMan
04-12-2013, 06:04 PM
If it happens in 1st maybe check PH?Had a similar problem once and turned to be PH.
drimouxlas
04-12-2013, 06:17 PM
Ok but nothing changed when i did the prindhead skew reset and the machine is already working since summer on a logistics department and it has about 70000 printouts. I mean most ph problems occur the first week..but i ll get a ph unit and a belt with me monday morning just to make sure. Thanx for the advice
Itsthepaper
04-13-2013, 03:37 AM
I'm taking a shot in the dark and piont to the transfer belt, yellow transfer roller could be out of place or binding. DON'T Forget to do a new release so you could put the belt back in the box as new if it doesn't fix the problem.
blackcat4866
04-13-2013, 04:00 AM
Just curious: What is the interval between the pattern of peaks? Does it correlate with the diameter of any particular roller or rollers? =^..^=
dshiels_17
04-13-2013, 08:14 AM
There is an FOC part DrySurf p/n U2260482FOC which was available for order in US/Canada up until March 29,2013. Used to lubricate levers on 1st transfer rollers in the belt unit. The problem is in the belt, lubricate levers or replace belt.
drimouxlas
04-13-2013, 07:11 PM
Thanks everyone. i will look for that part dshiels_17 and i'm going with a used belt monday morning to check results ill let you know thanks again for your time.
drimouxlas
04-15-2013, 10:38 AM
Good job thank you all replaced the belt works perfectly.:cool:
