fuser grease
  • peanut
    • Oct 2005
    • 10
    fuser grease
    I work with mainly ricoh, savin, etc and I\'m looking for the best high temp grease with out a stench.
  • imagertech
    • Apr 2005
    • 41
    Re:fuser grease
    i use lubriplate from katun but i find i dont use fuser lube that much any more with the hightemp plastic parts. i do use it on the lower bushings in the smaller sharps.
    • 10871087
      • Jan 2005
      • 1143
      Re:fuser grease
      Mita used to sell \"Temp-1\" grease that worked ok back in the day but for the past 6 or so years I have been using a product called \"Super Lube\", you can pick it up anywhere. Its a clear synthetic oil that comes in a pen type oiler. its rateed for about 400 degrees but I have never had a problem with it in fusers. It\'s a very thin oil so a drop is almost more then enough for any squeek.
      I agree with Imagertech, I haven\'t needed to lube a fuser in a while. I feel that most copier an printer noises have nothing to do with a lack of lubrication. 97% of the time noise is caused by dirty bushings, shafts, clutches... A little cleaning or a new set of $10 bearings will last longer then a lot of oil.
      • peanut
        • Oct 2005
        • 10
        Re:fuser grease
        Thank you for the help
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          Re:fuser grease
          You can also get superlube in a tube that is grease instead of an oil.Check with katun or Ames supply. Ricoh reccomends and sells mobil temp 78. thats the dark grey high temp grease. They also use barierta grease for the fuser bushings, but it ain\'t cheap and I\'ve only seen it from ricoh.:evil: :evil: :evil:
          Mystic Crystal Revelations
          • 10871087
            • Jan 2005
            • 1143
            Re:fuser grease
            Which ever grease you use, make sure you slather it all over everything. Put on enough so that it can dry out in a month or so and turn into tar and cause all kinds of strange drive system drag problems. Unless you using something that comes in an aerosol can. If so, make sure you spray enough to coat the entire back of the machine and don\'t forget to hit all the clutches and the idlers in the exit area.
            Any old tech can clean, but only a stud tech can transform a well running machine into job security with a can of WD-40.
            Oh well, just my attempt at humor after a long Monday. :S
            • galexander37
              • 16
              fuser grease
              agree
              g
              • wagon
                Village Idiot
                • Dec 2006
                • 654
                Callbacks - the iron clad guarantee of job security (to a point!). What about only half doing a pm? Grumble. Rant. Rave. Whack. I feel better now.
                If you are hitting your head up against a wall it always feels better when you stop.
                  • 22997
                  Molycote HP-500 Grease
                  Try Molycote HP-500 Grease. Its made by Dow Corning (sharp part # UKOG-0235FCZZ). The Sharp color machines are know for "click, click, clickclickclick, click..." whenever the fuser rotates. Smear this stuff on the ends of the driven fuser roller to stop the bearings from rocking back & forth.
                  Second choice (distant second) Chemplex High Temp Grease. It runs all over the place. It stinks, but doesn't burn.
                  • konitech
                    • Jun 2007
                    • 20
                    i learned this from an old xerox guy, years ago. he had come out of retirement because he needed medical insurance. he started out working on the very first xerox copier. He told me that you can get all kinds of stuff to lubricate fusers, but the best thing is automatic transmission fluid. it's made to be a long lasting, high heat lubricant. put a little in an oil bottle and yer set. it's cheap, plentiful, and i used it for years. works great, especially on bearings...but remember, with lubricant, use only what you need, and put it only where you need it
                    • philjessen
                      • Jun 2012
                      • 10
                      Re: fuser grease
                      Ricoh fuser bearing come from the factory packed with a fluorinated grease called Barrierta. If you mix any other type of grease with fluorinated grease they nullify each others lubrication properties. DuPont Krytox grease is a fluorinated grease completely compatible with Barrierta with an even wider operating temperature range. Available from Image Supply Service. Image Supply Service
                      Phil
                      • jmaister
                        certified scrub
                        • Aug 2010
                        • 755
                        Re: fuser grease
                        MolyKote 300 is used for fuser gearing, actually listed as a part as well.
                        I'd call MolyKote and find some heat friendly spec-ed grease, help line lady is friendly.
                        Idling colour developers are not healthy developers.
                        • Iowatech
                          Not a service manager
                          • 3930
                          Re: fuser grease
                          I don't know if it is available anymore, but I used to use Slick 50 One Lube grease when I ran out of the high temp version of Krytox back in the day.
                          • Tonerkiller
                            • Oct 2012
                            • 668
                            Re: fuser grease
                            In 17 years I have never put grease on fuser gears so I have no use for it now either.
                            • Venom
                              Technical/IT Support
                              • Nov 2009
                              • 765
                              Re: fuser grease
                              Hot roller bushings would always make knocking noises on Ricohs so grease was the only fix. I doubt anyone wants to grease fuser gears.
                              IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
