XEROX WC7535 CALIBRATION
  • seximibabay07
    • Mar 2013
    • 59
    XEROX WC7535 BAD PRINT QUALITY
    bold.
    i follow this step to calibrate the machine
    Machines Status-->Tools-->Troubleshuting-->Calibration-->Print Calibration
    I did all the correct steps and comparison of calibration more still remains the same, switched to another printer and printing WC7435 this perfect.
    swapped with a new printer and the problem continues wc7535, wc7535 tested over another and the problem continues even after calibration. when I print from any printer does not work correctly defines the lines of print, the letters and the lines appear bold.
    wc7535 all printers are the same both new as we just installed.
    how can I calibrate these printers and set a good print quality???
  • redzventures
    Service Tech
    • May 2009
    • 45
    May not need calibration...
    It sounds like you have a print driver issue or a document settings problem. I'm struggling to understand your exact problem but it sounds like you're having the same problems with different machines of the same model. Sounds like font issues which you may be able to get around by selecting "Print Text as Photo or graphics' in the print driver.
