axyun
05-01-2013, 07:02 PM
Customer moved Bizhub C203 without disconnecting Ethernet cable thereby damaging connector. Customer had to use USB until repaired. I disconnected MFP board and took to a friend who desoldered and repaired and resoldered connection back to board.
I reinstalled board but not machine won't go into ready, no display and no motors. Just hear fan come on in back.
When I turned power off before removing board I turned off main power switch behind front without having turned off power from operation panel first. Is it possible I caused a problem with power supply or is it more likely a problem on the MFP board my friend worked on. There were only 3 connectors. The one on top right side-by-side connection, the hard drive connector and the ribbon cable under the other 2.
Any advice you can give is very much appreciated as long as it isn't to stay away from Bizhubs(joke). I hope you are having a good day, Frank/ActionPhotocopy
