I have a paper lift motor not working...tested in I/O output and it isn't firing up at all...no error code listed that it's not working....so got a motor on order....I was going to swap motors to test it for sure but I got about halfway in taking off the IC, HDDs, and such....looks like you gotta take out the whole damn main board unit....any tips or tricks from anyone who has done this as it looks like this job is gonna suck and the manual doesn't really show instructions on replacing the motor...just removing the main board unit.....
c7000 paper lift motor /3
Re: c7000 paper lift motor /3
update on this...turns out after looking at TOE for the lift motor, realizing the tray is also not detecting the paper size correctly I did a bit more digging...seems it was a loose connector on the paper feed unit for the solenoid that sits on the front side that helps lift the paper feed rollers....."In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
