IC-409 bizhub c550 config
  • bbamouad
    • Jun 2009
    • 18
    Hey everyone:
    how to configure the IP address for ic-409 in my bizhub c550
  • Setright
    FSS / SPM
    • Nov 2008
    • 247
    Re: IC-409 bizhub c550 config
    You need to access the "Controller Settings" via the Administrator menu on the front panel if you don't know the current address.
    Since the Fiery and the Emperon (engine) have to communicate you need to be patient. Once you enter the Setup of the Fiery, the buttons will come and go until you finally have access to the menus.
    Difficult to explain in writing.
    If you know the current IP address you can access the "Configure" button via a webbrowser.
    You can also find the controller using Command Workstation and reach the Configure/Setup that way.
