View Full Version : Error Code Xerox 5675- system unavaillable- communication error
gregoriojc
05-19-2013, 11:08 AM
Any one can help me pls. the xerox 5675 when put on the display is showing''system anavaillable. do not power down untill message appears'
and then after a while is showing " communication error"
please need help
gregoriojc
555555
05-25-2013, 05:36 AM
Resetting the device has
The default
That part does not make an error check now
Cable connection or replace it
Czech flat cable
gregoriojc
05-25-2013, 11:29 AM
The default
Czech flat cable
Ok thank you very much, I will check the cables and wiring:)
CaptnRed
06-04-2014, 05:45 AM
I'm having the exact same issue! Were you able to resolve this Communication error?
