View Full Version : Jamming C224jam
amigoami
05-21-2013, 06:38 AM
C224 jumps exception paper jam 99-01
From one or two cartridge
Separate test print lost ten
Paper will intermittently stop before synchronizing
Replace the synchronous clutch is not valid
Invalid update firmware
Gaffers01
05-21-2013, 09:33 AM
C224 jam Code 99-01
The paper sporadic sent synchronous roller stops
Separately from the of ten blank page test print from time to time
Updated firmware is invalid
The first with the second cartridge will
How and solutions
To replace the MFP version or PRCB
If not,
Board replacement with re-machine no longer a
You What?
Avskrap
05-21-2013, 11:05 AM
I suggest not using Google Translate.
EarthKmTech
05-21-2013, 11:11 AM
if its from large capacity tray 3, its because the piece of crap 1 way gear on the transport roller falls apart.
It can be held together and prevented from failing again by using the spacer shims in 2 x "support kit" used on feed rollers.
JustManuals
05-21-2013, 07:44 PM
Paul@justmanuals.com
