View Full Version : Miscellaneous Toner compatability between KM C203/253 and develop ineo+ 203/253
backspace
06-07-2013, 08:12 AM
Hello
a client have a develop ineo+ 203 and he would like to Toner of the KM C203/C253 instead of the develop ones. Because we dont have toner for Develop. Is it same or some option for inserting toner of KM C203/C253?
Mitch Barron
06-07-2013, 12:45 PM
That will work. They are same machine. Names are just different. KM is Develop and vise versa. Happy trails.
backspace
06-07-2013, 05:04 PM
Thanks for answer but it seems it is not same toner. Ther is problem inserting and problem with chip. IU is same but toner not.
Mitch Barron
06-10-2013, 06:48 AM
Is it an original toner? should go. It's the same machine. I have never had that problem, but i guess if it doesnt go for you then there is obviously a problem. Sorry for leading you astray. Best of luck from switzerland
copyman
06-10-2013, 06:28 PM
They are the same machine but each company that puts their name on it wants the exclusive toner/IU rights. So chips are different as well as the end caps. You can take the end caps off the old toner and swap to new toner, install proper chip and toner will work. NEC supplies are the only supplies that are cross compatible with Konica Minolta branded models. Most likely because NEC makes the equipment for K/M
