Not sure whether is the scanning lamp issue? Because only when make photocopy the result is terrible. But when print the demo is OK... please help...
bizhub 350 copy failure.
Re: bizhub 350 copy failure.
One would like to see a real scan of that copy instead of a fuzzy smart phone picture. At the same time a scan of a printout from the same original would be good for real comparison.
I hardly believe that the printouts of this machine are good.
Hans" Sent from my Intel 80286 using MS-DOS 2.0 " -
Paul@justmanuals.comComment
well, its within the printable area with the clearly defined margins, so its not going to be the printer engine.
the image reading optics, lamp or the ccd will be the problem.
The mirrors are notorious for getting filthy in these machines, although that usually results in light copies. I'd start by cleaning out the scanner, properly that is.Comment
this problem look like the original paper lifted a little bit at the edge. try put another 20 pcs of fresh paper on the original paper.
Until the original paper all are touch to the platen glass properly and then do a copy.
Regards
MatokuComment
