Hi guys. I have recently installed a KM Bizhub 1050 at one of my customers, it replaced a Ricoh MP9000. Machine is used 1.4 mil but seems OK, we changed upper and lower fuser rollers on it, it will need a few more miscellaneous parts replaced but there is few questions I'd like to ask...
It is running a 22 page doc on regular 20lb paper, corner stapled, 1000 sets.
Problem #1 - it jams, issue seems to be that machine can't spit the ready set all the way out - is it a common problem? Anything specific I should be looking at? paper is fresh, just out of the rim/box.
Problem #2 - (It made me smile looking at it) when it runs, it outputs only 30 sets and asks to remove paper from output tray, I smiled because this thing is half of the car lengths-wise and stopped and asked to remove 3 inch of paper that it had printed. I was like - "Thats it, is that the best you can do?" Pretty much corvette with 100hp engine like
Is there a way to over-ride that?
Problem #3 - It would not continue on its own, meaning that after removing a paper jam or adding paper or removing printed media, i have to wait for "Start" button light to go green, press the start only than I can walk away, for many years in business, I can say that I had seen them all, at least most of them but never had to babysit the machine to tell it "Yes I want you to continue" Is there a way to disable this please?
Guys It may seem a rookie question, yes, this is my first KM...
Thank you for your input.
Roman.
Roman.
