754 new install
  • emujo
    • Jun 2009
    • 3009
    [Misc] 754 new install
    Brand new setup, went to configure email settings, and under NETWORK/EMAIL, the only configurable option is POP. SMTP, and S/MMIME are missing (via pagescope). Scan to email is "Allowed", billing settings/management settings are "Unset". Onsite tech says through the control panel SSL is on and when he sets it to OFF all the settings grey out. sending him back out to reload firmware today, but looking to see if this has popped up for anybody else..Emujo
  • B0265
    • Jan 2007
    • 718
    Re: 754 new install
    If you are using IE 10 turn on the compabilty view. Fix site display problems with Compatibility View - Microsoft Windows Help
    • emujo
      • Jun 2009
      • 3009
      Re: 754 new install
      I will have the tech try that, but from what I saw (did a quick "go to assist with tech) it looked like the page was loading perfectly. Normally when you select an item on the left side of the page it will expand and show you the sub levels, all other areas work fine...if you expand LDAP, you can see all the options...on the email selection, there is nothing but POP. Emujo
      • emujo
        • Jun 2009
        • 3009
        Re: 754 new install
        Looks like a f/w reload did the trick. Emuoj
