View Full Version : km4550ci u0640
andyf424
06-27-2013, 04:46 PM
First time poster, long time reader. Hopefully I don't make a fool of myself with a dumb question!
Have a 4550 in our showroom which was intermittently giving us an f000 on startup, which service manual and this forum pointed to main pwb and operation pwb as the wiring harness checked out. Parts came in and I swapped everything out.
Now on startup I get a u0640 which is Hard Disk Error, I've checked connectors and ran U024 to initialize but nothing. I updated firmware, which went smoothly except I got an error on the PDF portion. Could the HDD's failed also, perhaps just coincidence?
I'm new to the forum and new to working on MFP's so any suggestions are appreciated. Hopefully, in time, I'll be answering other peoples threads.
spandx17
06-27-2013, 06:43 PM
It could have been the HDD in the first place. I had a similar issue with a HDD problem
blackcat4866
06-27-2013, 11:23 PM
Ditto that.
FINGERS123
06-28-2013, 02:44 PM
Replace the code dimm also just had the same problem
andyf424
06-28-2013, 05:57 PM
Thanks for the heads up, HDD's are on order.
andyf424
07-17-2013, 02:40 PM
HDD came in a while ago but I've been busy with actual customer machines so I didn't get a chance to install them until yesterday.
Installed hdd, loaded new firmware, turned it on...... f000. Rebooted machine thinking maybe a fluke. Booted fine, print maintenance report, go to make some copies and now it's showing F183, which isn't in the service manual.
I've found a couple mentions via Google but nothing concrete. Any suggestions?
blackcat4866
07-18-2013, 01:29 AM
You probably should have immediately re-loaded firmware after installing the HDD. It may still work. =^..^=
madas
07-18-2013, 05:28 AM
Had a few of the HDD's bomb out on this range.
thekeg19
07-18-2013, 08:33 PM
HDD. Have had nearly a dozen fail.
jibacoa
07-20-2013, 08:45 PM
replace Flat hd
dyodyo
07-21-2013, 12:45 PM
Have you tried replacing the Memory?
Initialize the Memory after reformatting the HDD. I had this trouble before.
Now for F183, hope this works.
F18x - An error is detected at the Video control section.
Either Engine board or Main board. Try replacing the Engine Board first.
Then update the F/W.
Hope it helps. Thanks!
andyf424
07-25-2013, 10:03 PM
Main board has been swapped..... haven't swapped the engine board. Got a call into Kyocera so it's out of my hands. Once/if they can solve it I'll pass the info along.
JimHegs
08-01-2013, 10:56 PM
Also try the SATA cable that connects the HDD, we have had at least two machines with ongoing HDD codes where that was the fix.
Mhodges
08-02-2013, 04:48 PM
Normally this problem is caused by the SATA cables. On early machines they were quite flakey! I have had several of these, normally the SATA cable fixes unless customers have not been powering the machine down correctly, then the HDDs fail.
eddie110171
08-06-2013, 02:31 PM
I had one with the cf000 and the c0640 replaced the hard drive and ran mm 024 and mm 021 worked fine afterward and since yours is a showroom machine you have no customer info to lose.
