View Full Version : C451 black drum problem
mrfuser
06-27-2013, 08:36 PM
Had a clicking noise and found it was a bad drum for black. We swapped it with new one for client and now the new one is building up mounds of toner on rear left portion, and the clicking noise is coming back!
Any idea why?
thanks
kelly
mo0651
06-27-2013, 10:06 PM
rear left sounds like a used toner auger blockage or (clicking) the gears are slipping that drive the transfer belt on that end. There is an update on gears and bracket.:cool:
mrfuser
06-27-2013, 11:21 PM
Do you have the updated part numbers or bulletin you can send me?
Kelly
BR549
06-29-2013, 05:03 AM
Do you have the FOC black IU holding plate installed? It fixes a problem that causes toner dumping.
mrfuser
06-29-2013, 05:13 AM
No, part number and pic please
antoney suresh das
06-29-2013, 04:33 PM
after replacing a new drum did you find mounds of toner build up or is it developer??
BR549
07-01-2013, 03:07 AM
Tech bulletin 7370. Part # A00JP33100
Konicoz
07-02-2013, 03:47 PM
Any idea why?
thanks
kelly
is it dev or toner?
mrfuser
07-02-2013, 04:44 PM
toner.
Anyone know where I can get the holding plate?
A00JP33100
Kelly
mrfuser
07-19-2013, 05:08 PM
No one? Nobody has a plate they can spare? No one has specs or measurements so we can make one?
Beuller? Beuller?
Kelly
EarthKmTech
07-19-2013, 07:37 PM
these were being handed out by the million by km for free.
as far as im aware they are still free, I still have more than 25 i will never use.
btw, its not the be all and end all fix for failing c451 black imaging units.
i've had machines kill the black imaging unit once a week, only to end up replacing the HV1 board to cure the problem. even then you can change everything including both hv boards, the laser, the belt and black iu and it still happens. (with the plate of course) then its time to roll the machine off the nearest jetty into the ocean. At a grand a pop it starts geting expensive fast.
OutlawTorn
08-21-2013, 10:24 AM
Can someone show me how this plate is fitted to the black IU, I have a couple but can't figure out where it goes!
BR549
08-21-2013, 10:35 PM
try this
doinbox
08-25-2013, 11:26 AM
It may be that the K hopper seal needs replacing. I have replaced many on C451/550/650 with high click.
