View Full Version : FS-1135?
jewen25
07-04-2013, 02:22 PM
Is this Fs-1135 is better than Fs-1028? Any comparrison for this? In terms of perforance?
Venom
07-05-2013, 02:41 AM
not much different
copymech
07-05-2013, 03:39 PM
the 1135 eats fusers like candy.
Kidaver
07-05-2013, 04:16 PM
The 1028/1128 didn't? I know they revised the fuser and firmware for the thermistor grinding into the fuser roller as I've replaced more than I care to remember...hell replaced 4 in the last week and a half...I've not replaced any 1135's....same problem or different issue?
copymech
07-05-2013, 08:03 PM
did one the other day. grinding noises and fuser had grooves worn into the upper roller. but overall they seem to work better than the earlier models
Kidaver
07-05-2013, 08:21 PM
Man I really hope these 1135's don't go down that road....I can change these fusers in my sleep I've changed so damn many....you'd think Kyocera would fix that design flaw....
JR2ALTA
07-05-2013, 08:29 PM
Thermostats scratching heat rollers? Maybe they're designed by Konica
Kidaver
07-05-2013, 08:40 PM
They do a little bit more than scratch...they carve into the roller...I had one customer who ignored the loud grinding noise and ran it until he cut the roller in half....
jewen25
07-11-2013, 02:24 AM
Thnx for mORE info.
JR2ALTA
07-11-2013, 03:05 AM
Thnx for mORE info.
1135 has secure smtp for gmail, etc
10871087
07-11-2013, 05:29 AM
not much different
Agreed, but see the fuser comment above.
altech
06-16-2016, 01:32 AM
Does anyone know what cause the thermistor to suddenly drop down on top of the roller causing it to wear?
Kyo fan
06-17-2016, 09:17 PM
The plastic BUSH HEAT L and R wear down over time (sooner than they should) which causes heat roller (which revolves inside them) to drop down and the first thing it touches is the thermostat underneath it. Kyocera has updated those plastic parts by changing material, but it could be better.
altech
06-24-2016, 03:52 PM
Kyocera has also released firmware to resolve this issue.33340
