View Full Version : It is the technology of the copy machine in Japan.
osamu takahashi
07-11-2013, 12:08 PM
Nice to meet you
We are touching the copier CANON mainly, but messing with the SHARP MX2310FN this time, and you can not reset it becomes L4-16 at the same time as the power is turned on. FUSER and also check, there is no problem especially pressure sensor. Do you have a case like this? Please forgive me strange statement because it uses the translation software.:混乱:
Aneurysm
07-11-2013, 12:24 PM
Welcome Aboard!
DWise
07-11-2013, 02:08 PM
Welcome to CTN!!
You should try to post your question in the Sharp forum for a better response
==> Sharp (http://www.copytechnet.com/forums/sharp/)
Nice to meet you
Trouble content A change in the fusing pressure release sensor signal
cannot be detected within the specified time after
outputting the fusing pressure release motor.
Detail PCU
Cause Fusing pressure release sensor trouble.
Fusing pressure release motor trouble.
Pressure release drive gear and pressure release idle
gear trouble.
PCU PWB trouble.
Connection trouble of the connector and the harness.
Check & Remedy Replace the fusing pressure release sensor.
Replace the fusing pressure release motor.
Replace the pressure release drive gear and the
pressure release idle gear.
Replace the PCU PWB.
Check connection of the connector and the harness
HenryT2
07-11-2013, 09:36 PM
Welcome !!!
osamu takahashi
07-18-2013, 09:19 AM
Detail PCU
gear trouble.
PCU PWB trouble.
Thank you for everything. It was replaced with a new one fuser but the situation did not change. I think you try and replace the PCU substrate assembly of gear because it is also all right.
Thank you!
osamu takahashi
07-18-2013, 09:21 AM
Welcome to CTN!!
Thank you.
I will ask in the forum of SHARP
