toner swap between C550 and C552
  • Gar the pilot
    • May 2025
    [Misc] toner swap between C550 and C552
    Can the toner from a c552 go into the c550 with just cutting the tabs? We just replaced the c552 at our Clients office, but have another Client with the c550 and they need black toner. Just hoping to use up our leftover toner supply.
    Thnaks
    Gar the pilot
  • emujo
    • Jun 2009
    • 3009
    Re: toner swap between C550 and C552
    The C652 series has developer mixed in with the toner, not sure if the C650 is the same way. But even so, I wouldn't try, probably end up replacing the drum and developer to fix. Emujo
    • Gar the pilot
      In the past we have used TN-413k in the C552, just had to clip ctg tabs. That swap worked fine. and swapping back between the 613K and 413K have gone with out problems. I was just thinking the 550 and 552 are so close, that no problem switching would come up. xfer roller swapped ok, and looks like fuser would swap too. In the Mita's the 6230 ands 6330 were so close most everything interchanged. these Bizhubs Look to be the same with the 552 the up-grade to the 550 and with most things interchanging.
      My main line is the Mita's but have worked with Minolta's off and on starting with the EG101.
      Looks like a nice weekend coming, I am going to paint at My Mom's ( she's 92 ) and then go fishing or flying.
      thanks
      Gar
