View Full Version : Hard Disk location on C250, C350 and C550
onie
07-17-2013, 07:26 PM
I'm not sure if the C250 and C350 have hard disks but pretty sure a C550 does. Where would it be located? Can anyone tell me what panel(s) to remove to expose the hard drive?
JustManuals
07-18-2013, 12:13 AM
These Parts & Service Manuals can now be purchased for $12.77 and downloaded immediately after payment from:
Paul@justmanuals.com
johnyb
07-18-2013, 08:01 AM
Its on the controller.
you need to remove the back panels.
EarthKmTech
07-18-2013, 10:59 AM
on the c550 its hidden by the printer control board cage.
you do not need to disconnect and remove the printer control board its cage swings out independently if the correct screws are undone.
C350, cant remember, too long since i worked on one.
C250, cant remember either, but it wont be hard to find after the rear cover is removed.
copier addict
07-18-2013, 05:25 PM
On the C350 the HDD was an option, so, it may not have one. C250 will be behind the rear cover.
TheOwl
07-18-2013, 11:58 PM
After removing the rear panels on the machines, you then need to remove the access panel on the shielding box which also contains the MFP board.
On the C250, it was on the right hand side of the shielding box as you are looking at the rear of the machine.
C350 had the HDD with the MFP board from memory.
Depending on where you are, HDD's were optional on both of these machines. Some countries did decide to make them mandantory though by the country distributor sending HDD's when you ordered the machine.
onie
07-19-2013, 12:22 PM
Thanks for all the helpful information. Much appreciated.
