Solotime
07-29-2013, 11:12 PM
OK, so I know how to go into the service mode and change Stop to NO Stop on the Minolta. But I have been asked to work on a CM3522 that is saying to replace an Imaging Unit soon. The life is not over yet and I want to keep it running until the IU's come in. The CM3522 shows only Normal or Suspend under the IU Life Stop Setting screen. I guessed and set it to suspend. I based this on the fact that it was set to Normal and since the KM machines default is Stop, I assumed that Normal = Stop and Suspend = No Stop.
Hope I was right.
So my question is if you do not want the CM3522 to stop when the IU life counter ends then do you set it to Normal or Suspend?
Thank You!
Hope I was right.
Thank You!
