MadCityCopy
08-05-2013, 01:38 AM
So I'm having an issue with my favorite machine. To start its technically an NEC IT45C. Same as the C451 box. The issue that came up this week was print registration is all out of wack. No previous issues for years. 850xxx prints. I run all the calibrations and adjustments and it still is off. I included a scan of my skew adjustment print out. On her print outs she is trying the text and color are just mis-aligning and some have shadows. Seems to be mostly magenta thats out of wack. I have read around and found the other thread about the P-14 code, which I am also getting now.
According to the book I should...
1. check the drive of the IU
2. clean IU contact
3. check the IDCS sensors
4. chance said sensor
5. change image unit
6. change PH
7. change REYB
8. change PCRB
Up to this point I have checked all IU's and drive. Cleaned the IDCS sensors. And changed the PH unit. My next stab I was going to bring a few IDCS sensors amd te REYB. Possibly all new IU's. I have tried new magneta. New K IU, new t-belt, and t-roller. I have also reset the skew for the new PH and manually set the skew. Any thoughts? Id love to try the special firmware but seems I friends at NEC closed up shop. Plus I have not attempted to reload firmware before on this beast.
More notes, from all my adjustments it seems to balloon in the center of my registration test chart. My scan is only that of an 11x8 1/2 but I did that on a ledger.
2. clean IU contact
6. change PH
7. change REYB
8. change PCRB
