View Full Version : Error Code ineo +224e abort code
macuk
08-05-2013, 05:47 PM
Sorry, new to this machine. Have just unpacked a new one in the warehouse and am getting cf902 abort code. Have checked connections to mfb and tried resetting code but with no success. Has anyone had this code? Is the board faulty? Is there anything else i should check?
Thanks in advance for your help!
emujo
08-05-2013, 09:13 PM
manual mentions a open IPC13 will generate this code...protection from the temp/humidity sensor. You should replace both the sensor and the MFP board. Emujo
macuk
08-08-2013, 01:11 PM
hi, have now replaced sensor and board at same time but still have the same code! any ideas?
B0265
09-05-2014, 09:55 AM
Did you find the solution?
