View Full Version : Miscellaneous Fuser Rebuild Kit for C6500
AlSyed
08-07-2013, 12:02 AM
Hi Guys, I know there is a kit to rebuild the Fuser Unit that has Rollers, Gears, Belt and colors etc. Please kindly give me the Part number to order and if some one know the list of the parts this Kit has. Sincere Regards in advance.
bizhub1
08-07-2013, 03:08 AM
Don't know of any kit to rebuild fuser. There is a 100k and 200 k kit for that includes trans. Belt and rollers, etc. I believe all parts need to be ordered separately.
methogod
08-07-2013, 09:16 AM
why do you want to rebuild?
run till fail...
replace belt when you see imperfections or marks....
I have 2 fusers for 3 machines, we run the crap out of them...
even the lower roller which is in the PM kit, we wait until there are failure or image issues.
Gears can last millions...
what is the problem...
blaze2000
08-07-2013, 12:56 PM
I'm not aware of any fuser kit either, possibly third party like Katun makes one. The only thing I replace as a set would be the belt and upper roller, otherwise it's pretty much peicemeal
methogod
08-07-2013, 01:24 PM
are you thinking of the top half of the fuser is avaialble as a part, UPPER roller, Belt, Drive Roller, Bearings, Bushings, Clips...
It was made for upgrading the C6500 to the C6501 upgraded part, i see them on ebay once in a while, if you ask me you can rebuild for alot less.
I have the video that shows how to dissemble if you need it.
AlSyed
08-07-2013, 02:02 PM
I believe this is what I remember as well. An Upgrade Fuser Kit. I also do the same suggested by other fellows to use the max of the Belts and Rollers etc. but his client heard about it and want to have it in stock to have it replaced when the imperfections appear. Any help for the Part number for this Upgrade Kit please and if possible list of parts this kit includes. Thanks again.
lnguye71
08-28-2013, 01:28 AM
methogod Re: Fuser Rebuild Kit for C6500
Hi Methogod. Would you please share this video.
methogod
08-29-2013, 02:32 AM
please let me know when you are all done...
https://www.dropbox.com/s/3n2wphil5nir83s/C6500%20Fuser.MPG
lnguye71
08-29-2013, 06:47 PM
Thanks methogod
In addition. Do you have some video or or procedure for:
- Replacing Developer unit
- Replacing developer power
- Drum, Belt. corona charge
Thank so much in advance
lnguye71
08-30-2013, 06:26 PM
I am done with this video. It is a great help. Thank so much
methogod
09-01-2013, 12:40 AM
nope, rest is in manual...
send me a pm if you need it.
rest is pretty straight forward too...
