View Full Version : Miscellaneous Need Firmware Imaging Toolkit 2006
gegione72
08-08-2013, 11:42 AM
Hi, I need the Firmware Imaging Toolkit for rewrite firmware in an konicaminolta bizhub c250.
I have try with cygwin but dont work , it dont write firmware to CF.
In the konicaminolta site the imaging toolkit is not present, if someone can send it to my email.... gegione72@libero.it
Thank you very much
JustManuals
08-08-2013, 03:30 PM
I have it but it isn't free. If interested, email me at Paul@justmanuals.com
Mick01
08-09-2013, 01:23 AM
Hi,
Here you go
gegione72
08-09-2013, 11:53 AM
Thank you very much, i have rewriting firmware with toolkit , the c250 is rebirth.
dinesh818@gmail.com
12-07-2013, 09:08 AM
Hi,
Here you go
thankyou very much
Canon.Tech
12-27-2013, 12:17 PM
Can I have more that one machine model firmware on one card? or can I only keep one model on each card?
Synaux
12-27-2013, 05:05 PM
In theory I would say probably, in practice, I never have and most likely never will.
You can get cards on ebay for about $5-10 not really worth adding any mixup and risking a bad FW write no matter how remote in my opinion. Not sure if the Toolkit will write two FW to one card either.
Canon.Tech
12-27-2013, 08:25 PM
Thanks for your reply. You’re right CF cards are cheap. But how do I know what firmware series is the same, EG is C451 the same as what? C550,C650!?
emujo
12-27-2013, 09:42 PM
There are specific firmware versions for each of the MFPs that use those CF cards. You can either gather the 6 needed versions and keep them in a stack, or use one card and re-write it. Just be sure to NEVER write anything but the color MFP firmware to the card or it will never work again (w/o using a special program to write 0's to the card). BTW, with over 1000 posts, how do you manage to have all those red cards? Who did you piss off? EMujo
Canon.Tech
12-27-2013, 10:02 PM
Cheers, thanks for the info, so basically to be safe I needto store firmware for each machine on a separate SF card? But my question ishow can I tell what firmware I have, eg what machine is it for?
I got red marks for supplying manuals & Canon firmwarefor free, but I prefer red to green! (apparently this site is run by sponsorswho charge!)
So anyone reading this message me I can supply many service& parts manuals for free. (NEVER pay for them)
Synaux
12-28-2013, 12:19 AM
Well, I simply hand-label all my CF cards the moment I write the FW to it to avoid any confusion.
Also, you can run the checksum to any FW to see if it will match in the Toolkit or cross-reference the checksum values with the pdf document that comes with the FW.
mojtaba_5611
05-14-2015, 03:30 PM
Hi,
Here you go
Tank you
very very very very much
Ayodeji
12-06-2015, 07:28 PM
Please how do I use the downloaded firmware on my C550. I don't see any USB port on the system
bungapads
12-20-2015, 01:15 AM
Thank you very much
Did you get the firmware to work? Is this the software that you use to reformat the harddrive? I have been locked out of my machine with a CE Password (no one knows what it is). I need to figure out how to reset the machine to factory settings? is this was you use to do that -...the firmware?
If so what is the process? I have downloaded the firmware tool, but I see no instructions? SOmething about a compact flash? where does this compact flash go? how do you reset the machine.
Help - ronaldbrilliant@yahoo.com if you can help.
bungapads
01-09-2016, 10:16 PM
I have to rewrite firmware for c550. I have the toolkit and a CF card (2 gig). I must be missing something. When I try to create the card with the toolkit it looks like everything is fine, but when I plug it into the machine it says that there is an error.
Questions
1. DO you have COMPLETE instructions on how to format the CF card?
2. Does the CF Card have to be 128 meg (or is that just what was available years ago?)
3. Any and all advice and details on how to do this reformatting would be greatly appreciated.
copier tech
01-10-2016, 10:44 AM
What firmware version have you written to the card? This is the latest version details.
Latest Mass Production Firmware for the C550 Model
1. Release version and download file name
The newly released program version and download file name are as follows.
[Release version]
<C550 MFP controller firmware>
Model
Program Name
Current Ver.
New Ver.
Program File Name
Checksum
Note
bizhub C550
MFP firmware
GPY-R6
GB1-R6
A00J0Y0-F000-GB1-R6.exe
CDBD
[Download file name]
C550_PRI_DLBT1300320EN.doc
2. What changed
Release of bizhub C550 (Special Program - Card Ver.GB1-R6 i-option2)
The individual files in the card and the checksum are as follows.
2.1. Revision of individual version Program nameFile nameChecksumNote
BOOT:A00J0Y0-1E00-G00-05874C
MFP controller subset:A00J0Y0-1F00-G00-7020E8
MFP controller:A00J0Y0-0100-GB1-R64C2B
MFP controller system: A00J0Y0-1000-GB1-R6----
MFP controller print controller: A00J0Y0-3000-G00-JD----
MFP controller print controller font: A00J0Y0-3F00-G00-44----
MFP controller print controller Demo Page: A00J0Y0-3E00-G00-00----
MFP controller MIO: A00J0Y0-5000-G00-00----
MFP controller PSWC: A00J0Y0-5100-G00-10----
MFP controller MIB IF: A00J0Y0-5200-G00-J2----
MFP controller IPP IF: A00J0Y0-5300-G00-82----
MFP controller OutSide controller IF: A00J0Y0-6100-G00-80----For Fiery
MFP controller TCP/Socket: A00J0Y0-6300-G00-J4----
MFP controller OPEN API: A00J0Y0-7000-G00-12----
MFP controller operation panel: A00J0Y0-8000-GPW-R6----
MFP controller PIC: A00J0Y0-8200-GC7-23----
MFP controller CSRC control Body: A00J0Y0-8300-G00-80----
Scanner: A00J0Y0-0023-G00-36364B
Printer: A00J0Y0-0050-GCA-22DA27
Panel CPUA00J0Y0-8900-G00-02----
FAX board controller: 15LA-0040-G02-13-000F105
Operation panel message data: A00J0Y0-8100-GFV-R6902B
ADF: A01H0Y0-0024-GC0-124C4D
Finisher (FS-517)A07R0Y0-00N1-GC2-227767
Finisher (FS-518)A07P0Y0-00N1-GC2-03AE5E
Finisher (FS-608)A07U0Y0-00N1-GC2-227767
RUA07X0Y0-00R1-G00-1131AC
ZUA07T0Y0-00H1-G00-02E8D4
(Copy Protect)----14C6
bungapads
01-13-2016, 01:57 AM
Hi,
Here you go
I have to reset the C550 CE Password. No one knows what it is. I have the Took Kit. I have followed the Service Manual page 80-87 approximately. Bought brand new unformatted 128 meg Sandisk CF Card. But still i get a cryptic response when I put the CF card in and then start the main and sub switches. It says. "This is invalid Card." " Make sure the Card". That is all it says. I do not know how it could be invalid when I followed every single step. I have tried a couple times, each time starting over from the beginning from formatting the card using the Tool Kit (not windows). I have verified the version number of the alleged software. Not sure what else. Hope you can help.
bungapads
01-13-2016, 02:01 AM
I have this "A00J0Y0-F000-GCQ-J8(00)". I decompressed into a "bizhub" folder on c drive as directed and then opened the toolkit, etc. But it did not work. I do i get the latest version and then I can try that I guess?
Thanks ROn
[Release version]
Model
Program Name
Current Ver.
New Ver.
Program File Name
Checksum
Note
bizhub C550
MFP firmware
GPY-R6
GB1-R6
CDBD
2. What changed
bungapads
01-13-2016, 02:03 AM
I also have version 2.5.3 of the ToolKit. Has this changed too? Can I use it with the new version below? Can you send me the new version below?
[Release version]
Model
Program Name
Current Ver.
New Ver.
Program File Name
Checksum
Note
bizhub C550
MFP firmware
GPY-R6
GB1-R6
CDBD
2. What changed
copier tech
01-13-2016, 08:34 AM
1st does the imaging toolkit successfully write the firmware to your CF with out any errors?
2nd what slot in the machine are you putting the CF card?
3rd if all the above works format the CF card in Windows, set file allocation to default then format & try again.
