View Full Version : Miscellaneous PRO c6000l problem with yellow
igorp86
08-08-2013, 01:39 PM
Hello I have problem with yellow developer on c6000l, after changing it was fine for cca 50.000 and again same problem, I changed dev. unit and developer, fine for some time and agan same problem ( yellow stripes in sub-scan diretion)
remati
08-08-2013, 10:05 PM
.yes ...there it is a big problem.
..and I know that very well and do the same that you do...
Try to adjust the doctor blade on the developing unit. (0,80mm) sometimes it helps
igorp86
08-09-2013, 09:21 AM
Did it alredy, also changed transfer belt, drum, image correction unit...., but no luck, i'm like crazy over that. I have noticed that I have that problem only on 6000l, on PRESS 6000, 7000, 8000 is everything ok. For now i changed color balance for yellow on -8 ( for now, but I don't thing it will last for long )
