View Full Version : Miscellaneous Developer drain from unit to waste box
cbp.patel
08-09-2013, 11:44 AM
I have c220 machine, developer drained to waste box, i clean charge unit but problem is still there
Zeldaman
08-09-2013, 11:47 AM
Hi there!
1. look if the DV-box is correct in place
2. check very good if all the HV-contacts are there where they belong
Greetings...
cbp.patel
08-09-2013, 11:50 AM
i check another drum unit then it works fine.
i am sure that problem in charging unit.
i clean it but problem is still there.
EarthKmTech
08-09-2013, 01:03 PM
as the dev units failed, replace the drum unit and developing unit as a pair, otherwise you will keep ruining developing units.
AjitN
08-11-2013, 02:21 PM
Charge is leaking.
Change Dev Unit as well as Drum Unit. It will solve uour problem.
