View Full Version : Error Code ALL Toners indicate EMPTY
AlanHubb
08-13-2013, 10:50 AM
I have here a Ricoh MPC 3500 with very strange toner issues.
The machine has a FULL set of new toners but still indicates in the colour level chart that ALL toners are out.
plus, on the bottom left of the touch panel it has been saying "Cyan almost empty" for the last 3 months.
But, after all this going on, the machine still works with no problems at all.
i have changed the Cyan toner pump and tube, along with trying other toner cartridges. (still no luck).
surely there has to be some sort of reset code in SC mode?
thanks.
:confused:
JustManuals
08-13-2013, 05:35 PM
Paul@justmanuals.com
Eric1968
08-13-2013, 06:03 PM
Are you using OEM toner or that aftermarket sh.t?
AlanHubb
08-14-2013, 08:41 PM
Im using Original OEM toner. (the good stuff).
Eric1968
08-14-2013, 08:47 PM
Have you checked any SC-codes that are logged? Could be an RFID-problem.
katash
08-28-2013, 08:16 AM
thanks.
:confused:
you need to do engine firmware and system should sought you out
Toledo
11-06-2013, 04:46 PM
thanks.
:confused:
check the following
SP 3901 001 NEW PCU DETECT (SHOULD BE '1')
SP 3902 001~012 MANUAL NEW UNIT SET (SHOULD BE '0')
ruben
11-06-2013, 07:47 PM
Or, faulty RFID board.
slimslob
11-07-2013, 12:30 AM
Since all four are bad it could be a loose connection to the RFID board or a bad board.
Process Control, MUSIC, and TC Adjustment are all forbidden during toner near end. Change SP 3519-001,002,003 all to 0 to permit these function when add toner is displayed. SP 3045 can be used to disable Toner End Detection.
Bantams
11-09-2013, 08:36 AM
Hopefully he's either fixed it or scrapped the mofo in the last 3 months since creating this thread :)
collme
11-14-2013, 11:39 PM
why scrap a perfectly good model of machine J lol
Helios
12-02-2013, 04:54 AM
It seems that these lot of machines are bad for not detecting new toner. 4502's seem to give me the worst grief when it comes to this problem.
