habik
08-14-2013, 05:22 PM
Did Modification of the paper lift motor plate KM bulletin
Did Modification of the paper lift plate top up as per Mercutio Norway
Did Modification as per Emujo rear screws removal
Have New tyres, other rollers and Sensors plus black pads are pristine clean, when loaded full to top machine jams half way usually with 6603.
When doing ADF paper passage test single or double in Service mode the machine freezes when above 6603 jam occurs.Tried different doc feeder same issue. Reboot required each time.
Reloaded with R6 firmware. Same thing.
Dusted all boards, power supply as it came from building site.
Jams in ADF usually half way through the Full load.
Any suggestions??
Any suggestions??
