View Full Version : Bizhub 420/500 adu clutches
dogsbody
02-21-2008, 12:56 PM
anyone else had the duplex clutches fail? I have now done 3 sets in four weeks all around the 100K mark. I would have thought they would last loner than that.
alexn257
02-21-2008, 10:36 PM
hi there ya i had to replace mine too it only had like 50k on it
Haroldbfix
02-22-2008, 01:42 AM
Non yet, however my 500's are still young. What are the symptoms?
dogsbody
02-22-2008, 06:24 AM
Timing is all out, I either get a couple of sheets jammed up in the rego rollers or two sheets coming out of the fuser. I don't remember the jam codes but the only thing that fixed it was replacing the clutches.
The old clutches didn't make much of noise however the new ones make a definate clicking sound when doublesiding.
erikijssel
02-22-2008, 10:43 PM
whe have same problem whe have raplace tree or four
jeroen2005
03-09-2008, 02:59 PM
We have the same problems.We toke them apart and cleaned them with a degreaser.The gears have a lot of grease on them and we clened them als well.We also found out that the top clutch is hiting against the metal frame .We placed a spacer to prevent this.
KMnyafayce
03-09-2008, 05:37 PM
I have come across that a lot. and they are fun to get out too. I see them go out about 100k or so. Be sure the FW is up to date also. :)
heyzuse
03-09-2008, 05:38 PM
I have had luck just spraying them down with electro-clean. It's a nelectronics cleaner. It also works on the di2510/3510 feed clutches.
