View Full Version : Konica Minolta C253 Printieng Issue
junidexy
09-02-2013, 07:14 AM
I have a issue in the printing Konica Minolta 253, all my other A3 prints are good, when I print through the Cyan color print, I am getting repeat shadow in the print, what might be the problem, any one please help me,
I attached the image also here
suomi
09-02-2013, 07:47 AM
Cyan IU
junidexy
09-02-2013, 07:50 AM
I change IU and Transfer belt also, still same issue , I clean the laser unit also and change at last change I change the laser unit also , still the same problem
Zeldaman
09-02-2013, 09:29 AM
Hi there!
Check the high-voltage-contacts & the fuser-unit.
Greetings...
junidexy
09-02-2013, 11:53 AM
Still has the same problem, no change
blackcat4866
09-02-2013, 02:27 PM
I'm fairly sure it's one of the imaging units, but it's unclear whether it's the cyan unit. What you'll need to do is make some heavy fill copies on single color mode, i.e. cyan, magenta, yellow, black. The source of your problem will become clear. =^..^=
Hansoon
09-02-2013, 05:17 PM
Try to download and print this pdf file. It makes diagnosing the fill of the separate colors more easy.
Herzlich Willkommen in unserem Download Bereich! - Support - Toner Empty Check (http://www.kistro.de/index.php/component/jdownloads/viewdownload/15-support/36-toner-empty-check.html?Itemid=68)
Hans
JustManuals
09-02-2013, 08:00 PM
This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
Paul@justmanuals.com
