View Full Version : Intermittent Add paper on tray 2
mdm7266
02-22-2008, 03:16 AM
i have another problem on konica 7050.
its intermittent "add paper on tray 2" even though there is enough paper on the tray. i have checked for paper blocking on the rear side connector of the machine - no paper obstructing the connectors paper size switches/actuators.
what do you think is the common problem on this tray? is it loose solder/contacts on switches on the rear side of the machine (printed circuit board switches.
another problem: tray 1 cannot detect legal size paper even i manually pushed the actuators on the rear side of the machine. it only detects A3 size.
CMB
02-22-2008, 11:10 AM
used to have problems withthose switches getting knock out of the back by customers slamming the trays closed to hard. i would leave them off for a while at certain customers offices to proove a point. you need to remove the rear cover and put them back in place against the frame.
