wseyller
09-05-2013, 11:23 PM
Brand new machine has this issue when I'm doing the install. I know they test this before delivery so maybe something happened during transport. Issue happens majority of the time. Every so often paper will come out fine.
The paper jams in horizontal conveyance code 7216. Paper crashes into the first pair of rollers in horizontal conveyance. I notice the rollers are going in reverse. Check RU entrance (ps2) and it will not switch as it stays on zero in sensor check. Made sure connections are good the sensor. Did not check where it goes to main board. Didn't have time.
It took this RU entrance off and have it with me. I'm likely to get a sensor first to try but is there any way to test if the sensor itself is bad?
Also are they any difference between these types of sensor. What I mean is can I take a sensor from say a bizhub paper feed unit to replace it. They look about the same. I noticed that the RU entrance sensor has written on it SG 364 and the spare paper feed unit I have has SG 571 on it.
Sent from my Galaxy Nexus using Tapatalk 2
