View Full Version : its C451 again ... copying issue
konica7022
09-07-2013, 03:23 PM
hi guys
bizhub c451 is giving following copy (its like half unfused toner on the paper)
but print comes out fine ?
2200922008
and can some one pls send me a service manual for c451
konica7022
09-07-2013, 03:54 PM
ok now its in the print as well
22010
but its only the black color that seems too be effected
EarthKmTech
09-08-2013, 06:57 AM
black imaging unit failure, for reasons mentioned a thousand times before.
search the forum
konica7022
09-09-2013, 04:30 PM
search the forum
thank you
thats what i suspected, so i removed the black IU and saw same toner/dev!! rolling on the drum, cleaned it and slide it back in
now its working fine again!
except of the paper ejection gear!
Konicoz
09-15-2013, 02:30 AM
Cleaning excess Dev off the drum will only be a temporary fix - it will come back and will most certainly affect c/q, you will need to replace the unit. There is a mod bulletin for the k drum as well that you can find on the km site
