View Full Version : Bizhub c250
bebe.radescu
09-09-2013, 08:05 AM
Km bizhub c250 transfer belt at it's life end, anyway, the transfer belt works just fine. I need to know if there's a chip or a way to reset it.
Thanks!
SmellsHot
09-09-2013, 12:30 PM
Theres a fuse. Should be located on the left handle as you pull the tbelt out. Look for the contacts. two screws, e-clip and one tiny screw will remove the cover to the fuse....
emujo
09-09-2013, 02:33 PM
FYI you must use the exact same fuse as original, if you don't you will blow PCRB and will need to be replaced. Might be prudent to just swap the x-fer belt with new one if you are not sure of what you are doing. Emujo
