View Full Version : Bizhub "e" series issues
SmellsHot
09-20-2013, 01:08 PM
Just want to see if anyone else is having issues with these machines. Every other "e" series machine I get has issues within the first week. So far I've had bad MEMS, HDD's, MFPB's, and PRCB's, as well as a handful of having to perform all data clears to fix the machine. And boy does it suck installing and fixing a machine in the same week. Not a good image for my company or Konica. Is anyone else seeing these problems?
jotunn
09-20-2013, 05:07 PM
Bizhub C224e - dead SSD after around 260 copies, machine hangs during early stage of bootup process (2 grey elements of total 5 on bootscreen) - just can't load part of firmware from SSD. It's 95% BGA soldering failure because of shitty RoHS directive, as with earlier (C224 series) PWB-MFP boards.
tsewk
09-23-2013, 08:45 AM
From my experience, it is better to perform clear all data and format HDD for all e series new machine
And the HDD is not as good as before, therefore you can try physically unmount HDD and start the MFP to check whether the HDD has problem
