View Full Version : Its possible to disaBLE Service mODe?
jewen25
09-22-2013, 07:43 AM
I ask this question for good purposes?it possible to change to other,or possible to disable?because there many tech.that not Authorized,i talk all wisecore machine,tnx
Eric1968
09-22-2013, 08:03 AM
Is not possible. And if it were possible, how do you do your adjustments without a service mode?
jewen25
09-22-2013, 12:15 PM
Is not possible. And if it were possible, how do you do your adjustments without a service mode?i mean its possible to change the service mODe 1087
Eric1968
09-22-2013, 01:43 PM
I think the factory can change that, but for us simple tech it's not possible. Don't know if you're into Ricoh, but the latest models have Service Mode Lock. The service mode is then protected by a password. When you fill in the password you can go into the service mode the usual way. I haven't seen this on the Kyocera's.
jewen25
09-22-2013, 03:06 PM
I think the factory can change that, but for us simple tech it's not possible. Don't know if you're into Ricoh, but the latest models have Service Mode Lock. The service mode is then protected by a password. When you fill in the password you can go into the service mode the usual way. I haven't seen this on the Kyocera's.so we hope kyocera's well do like ricoh
Newer machines support maintenance mode U010, but careful not to forget what you change it to.
