C220 producing fake prints and copies
  • kamoga
    • Jun 2013
    • 36
    Hi all
    my name is Brian and i was working on
    a printer c220 biz hub and it produces a test page like
    the attachment. customer told me that it just happened
    when he empted the waste toner box.
    i tried to stablize but no change, changed Drums,checked for
    loose connection but failed.some help
  • JustManuals
    • Jan 2006
    • 9838
    Re: C220 producing fake prints and copies
    Paul@justmanuals.com
    • occus
      • 327
      Hi Brian
      check the printout if it looks like smearing or like "pixels"?
      if you can see any pixels/squares then check, RAM and PWB.
      if it looks like smearing check transferbelt, drive to put out the waste toner...
      New belts have a modification for better transport the waste toner.
      have a look in the cleaner part of ibt, maybe toner in the tube is hard like stone.
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        mfp board.
        common fault that will come and go untill you change the board.
        it was probably just the act of closing the door that vibrated the failing solder joint under one of the ic's enough to render it useless.
        • 000nicec
          • Feb 2011
          • 14
          I have a C280 that gives a grey square in the background of all prints, copies and internal memory prints. The grey square looks pixelated.
          Any Ideas?
          • davidj7
            • 1107
            start a new thread . this one is taken
            a machine is only as good as your tech : source:screwtape ; the scary one
            • imihm
              • Feb 2014
              • 77
              Re:c360
              HI all
              We have c360 with problem of image belt life time does not go beyond 50k giving one side of the print faint especially on thick paper.
              any ideas
              imihm
