View Full Version : Error Code BizHub 420 Counter reset?
Joe Foe from Buffalo
09-25-2013, 01:50 PM
Need to know how to reset operation panel user warning to "Replace Fusing unit soon" I have looked in service mode and reset all counters for parts and also looked on the unit its self for a fuse like the older units use to have in the connectors. 22251
darry1322
09-25-2013, 01:54 PM
From service mode , go into System 1 and initialize the fuser.
09-25-2013, 02:10 PM
I don't recall seeing that option....anyone have a step by step from Minolta or can second I missed it some how
darry1322
09-25-2013, 02:20 PM
First answer was off the top of my head...
This is straight from SSD...
CAUSE: Incorrect settings.
SOLUTION: To clear the message:
1. Enter Service Mode.
2. Select [System 1].
3. Select [Initialization].
4. Select [Counter Data].
5. Select [Fixing Counter].
6. Press the Start button.
7. Exit the Service Mode.
Note: This problem may occur after upgrading the firmware.
Maybe you can understand that a little easier
09-25-2013, 06:33 PM
Hmm thank you....I must be blind. Will go back ASAP. Thank you again :-)
CraigW
09-26-2013, 04:57 PM
Firmware must be a 31 or it will not be available.
jjohnston12385
10-02-2013, 07:26 PM
Ditto on this. Had a machine that I couldn't clear the counter following the above procedure. FW update fixed this.
11-07-2013, 12:24 PM
Cam some one please set me up with the firmware?
