View Full Version : C454 C9403 code with dual scan adf DF701
faultman
09-30-2013, 10:55 PM
Hello guys
anybody come across this fault code with the dual scan document feeder, any information would be appreciated.
thank you
EarthKmTech
10-01-2013, 05:31 AM
Yes,
Several times.
And after changing everything the service manual suggests it was the black moulded display port data cable from the CIS in the ADF to DSCB in the back of the machine.
internal breakage occurs at the stripped and clamped down section next to the CIS.
faultman
10-01-2013, 07:38 PM
Yes,
Several times.
Thanks for the information, the cable you talk about.... Is it the one that looks a bit like a USB cable. Is it usually just this part that causes the fault code.
thank you
EarthKmTech
10-01-2013, 10:32 PM
yes, thats the one, and its black.
That's what it's been in my experience and given that its cheaper than most parts the service manual suggests its worth a try.
CraigW
11-04-2015, 04:22 PM
Got one giving 9403s a lot.
Going to give it a try....fingers crossed !!
CraigW
11-04-2015, 08:47 PM
Not too bad all in all. The manual has the procedure but left out the steps about removing the washered screws to be able to raise assembly, and access the screw for the white clamp.
Thanks for all the help on this issue provided.
blackcat4866
11-05-2015, 01:09 AM
This was my experience:
http://www.copytechnet.com/forums/konica-minolta/98511-bizhub-364e-c9403-cdfa1-c6753.html
CraigW
12-14-2015, 09:21 PM
We tackled the cable replacement and all is QUIET.
Thanks for the info on the cable and the tips.
EarthKmTech
12-15-2015, 01:04 PM
I did another one today.
every one of those early fat cables will fail eventually it seems.
1 is kept in my car at all times, its slowed down these days though since the standard fitment of the thinner cable from the factory.
Rylac
02-27-2018, 09:27 PM
Thank you so much for putting this info EarthKMTech!!
EarthKmTech
03-01-2018, 10:27 AM
Still the odd fat cable machine out there - I changed another one last week on a machine with 1 month contract left!
Soon all of this will be a distant memory.
