fixthecopier
10-01-2013, 10:30 AM
The original problem was a paper jam issue in the adf. I disassembled the adf and changed the two photocells for tale up and exit. When I reassembled and tested, it would give me a "matching size error". I ran the adjustment for min and max size on the adf, and now if you place a sheet in the portrait position, it shows it as A4. If I feed it in landscape, it works just fine, I couldn't find any other adjustment in the manual, unless I missed it. Any thoughts on what the issue is?
