View Full Version : C8000 Developer unit problems?
AB1984
10-02-2013, 08:19 AM
In our 8000 there's toner covering the top of every drum, and I had a look at the dev units, and they've all got a massive build up of toner on top of them (their own colour has built up quite thickly on that plastic flap).
Is this indicative of a problem with the dev unit, or the toner delivery bits or something?
Any speedy help would be appreciated
steve schofield
10-02-2013, 08:51 AM
Are you using genuine canon toner
Avskrap
10-02-2013, 09:59 AM
A C8000 is a Konica Minolta production machine, not a stinkin' Canon!
Avskrap, out!
steve schofield
10-02-2013, 10:25 AM
my mistake,,,,good luck
redhotrob
10-06-2013, 12:51 AM
I had one that had the same problem. It turned out to be from poor air flow from the waste collection system. My machine had old style tubes. I found my solution in the troubleshooting guide with modified tubes. Mine had black felt like around the intake of the tubes. The newer had a red felt like material around the tube intakes. If your's is newer, perhaps you've got a clog. The waste collection bottles were also modified some time ago.
MADSYS
10-10-2013, 10:48 PM
Check for clogging on Filter Assy ( right side of main body ).
